Remove battery and sim card and anything else including the Micro usb memory stick if you have it,
Put a cup of Dry Rice in a zip lock and add you cell phone to it and zip it shut. wait 24 hours and it will dry out the cell phone ..
Then try putting your cell phone back together if it didn't get burned out from staying connected to power while wet it should power up just fine. If not time for a new phone.
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
SOURCE: red light stays on
you will need to go into your menu under the system or display and turn off the LED indicator.
SOURCE: K850i charging problems and red light flashing at on/off key
Your battery is either not charged or the battery cell is completely gone.
I'll advice that you get another battery and give it a trial, also look out for the charging port. Check if it is not rust in any way because, if the charging port is rust, it will be difficult for the charger to contact the charging port.
I believe what's wrong with your phone is a minor fault, just do a thorough check and you will find a solution to the problem.
Best wishes.
