SOURCE: cant eject a dvd
Contact customer service at this number for help with your problem. service :1-877-467-4289. You can look on your unit and see if they have a pin hole insert for releasing the dvd drawer like on computer dvd's. They may not have this but its worth a look, also check in the owners manual to see if they have a method for releasing stuck dvd's. Hope this helps you with your problem.
SOURCE: dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
SOURCE: Emergency eject for Proscan TV/DVD
It sounds like the whole dvd unit may have failed, I have seen this numerous times on these combo systems... Try turning off the TV, then unplug the power from the power source for at least 5 minutes, then replug it back in. This is usually enough to kick start the dvd player to at least eject one last time. After that you will want to just use an external DVD player with this TV as replacing the internal one is as much as just replacing the TV and an external DVD player is less than $40 shipped here for example:
http://www.amazon.com/gp/product/B001IBHUU8?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001IBHUU8
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
SOURCE: I have the Proscan TV/DVD
Did ever worked properly?Is it wright one for unit that you have,you can check that in your owner manual,if not I will go back to dealer and ask for replacment.
