Lincoln Impinger Electric Countertop Oven W 31 Conveyor 208 V Logo
Posted on May 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i loosen the belt on a lincoln impinger 1300 oven? tks
Conveyor belt is too tight...afraid of burning out motor
johnny rebel
Level 3:
Top Expert:
  • Lincoln Master 10,875 Answers
  • Posted on May 23, 2015
 johnny rebel
Lincoln Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2938540
Points
47944
It was made that way,it will loosen with heat,its normal
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 • Ovens
Hi i 'm looking for lincoln impinger 1456
Google search "Lincoln impinge" and find your local service agent.
My Lincoln 1116 has a horrible high pitched squeeky sound off and on. What can it be?
The horrible high pitched squeaky sound in a lincoln oven could be coming from the moving parts more so from the main fan motor positioned at the back or it could be from conveyor drive system. In both you got to dismantle the motors if at the back replace the motor bearings.
Lincoln impinger pizzaoven
could be a defective pot or loose opitical encoder
7helpful
4answers
5answers
Lincoln Impinger Pizza oven 1301 model number
this could possibly be caused by the brushes in the conveyor motor. they might be worn out or sicking.
Lincoln impinger 1300
Check the air vents, Dust could be blocking air from cooling the circuits.
Top Lincoln Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
