Step 1, right clik on the file you want to access , select properties
Step 2 select security, you will get a security message select ok
Step 3 select advance
Step 4, select owner, go to change owner and select administrator or the file you want to change the owner to, select the following box( replace owner and sub container and object then select apply.
Step 5 security message, the following security message will appear( all permission will be replaced if you press ok.
Press yes
Select ok
Step 6 go to the file you want to access and it should open.
You can also download free hiren's boot cd. This is the best cd I have even owned for cracking of password and repairing computers
U can try restoring the bios to its defaults. If that does not work all u can do is get whatever files you want off of the drive and reload the unit.
