Changed out bulb...now lamp light won't quit blinking and can't get tv to come on...before I changed had sound and would come on just no picture.
SOURCE: Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
SOURCE: Replaced Lamp & yellow light indicator blinking. Still no picture
Good Day;
1. Check for an open AC fuse F9D00, if open check for a short on the 340v line to the lamp ballast between pin 1 an 5 at connector PL on the Power PCB, if shorted replace PWB-POWER LAMP (Ballast) part # 939P978010 and F9D00 part # 283D131040 2. Check for open AC fuse F9D00 part # 283D131040, if open check for proper seating of connector K1 on the Power PCB
Dead unit wd52525 mits
NO POWER
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
SOURCE: blinking timer light
The blinking timer light is usually caused by bad capacitors on the DM board. The V26 DM repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and the Cd with instructions.
SOURCE: after replacing lamp tv screen or sound will not
i
have been a tech for 26 yrs now i have seen so many postings on here
about bulging caps and so on but there is only 1 thing to do our
workshop has 18000 dollars in test equipment alone there is a great
reason for this the amount of vereables that can go wrong with nano
electronics there is no easy fix to this problem it needs to be seen by a
certified electronics tech this is your best chance of having this tv
fixed correctly im not putting down other techs on this site but some
things we can fix by computer network some we cant imagine even if this
tv was in my workshop right now it would take us over an hour just to
find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
SOURCE: mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
