I tried all the password I can rember, but no luck yet?
SOURCE: I forgot my password how can I open WD passport?
This one way for unlocking your WD passport but assume you will lost your data
Download wdsmartwareupdate here : http://www.wdc.com/wdproducts/wdsmartwareupdate/
Download instructions :
1- Locate you WD disk entry, click on Windows or Mac according to your operating system.
2 - Click on Download now link at the bottom and download the soft.
Unlock instructions :
1- extract the zip file you've downloaded en run the.exe.
2- select Continue to update and accept Licence Agreement.
3 - Next select Update Firmware
4- Check the check box "I understand ......" under Warning section, a button "drive erasure" will appear.
5- Click on drive erasur button
6- Wait until the end of the process and quit
7- Unplug/turn off the passport and plug it back in. Your WD passport is unlocked
SOURCE: my passport essential 750gb has
you can recover data from hard drive with asoftech data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
SOURCE: how to recover WD passport250 Data
you may try this hard drive recovery program called asoftech data recovery
SOURCE: Dear sir, it,s sumit agrawal.my 2tb
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
SOURCE: I Have WD Passport Hard
you can try some data recovery software. You can see
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
