Using VGA how do you connecct it
SOURCE: Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
SOURCE: My Aspire 5520-5140's curser constantly
You might have spyware messing with your mouse.
I suggest download Ad Aware 2008 (free software)
and run a full scan.
SOURCE: aspire 5520-5912 does not start ,shows only blue screen
Try to get into safe mode by pressing F8 when you first turn onto your computer. Choose safe mode. If you can get into safe mode. Try doing a system restore back to the last date the computer was last working properly.
If you can't get into safe mode then you'll need to wipe out your hard drive and get your system back to factory defaults. You probably have corrupt system files that are causing these problems.
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
SOURCE: How can I connect acer aspire one pc to TV using VGA/HDMI cable?
Try this link FUNNY THINGS...no virus promise...
