ACPI\ASD0001\2&DABA3FF&2 Listed as an Unknown device. It does have another device that is a PCI driver. I have had this issue since I did a clean reinstall of my Windows 8.1.
that is the "Quick Launch Buttons" driver.
Check the HP Support site for your exact Model and download it.
if that fails, see if the solutions on this page work.
BATTERY Microsoft AC Adapter Microsoft ACPI-Compliant Control Method Battery
COMPUTER ACPI Uniprocessor PC
Diskdrive Universal HDD
DISPLAY Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC Primary IDE Channel Secondary IDE Channel Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED SMC IRCC - Fast Infrared Port
KEYBOARD Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA Audio codecs Video Codecs Midi Control devices Legacy Video Capture Devices Legacy audio drivers Microsoft Kernel System Audio Device WDM Audio Compatibility Driver Microsoft WinMM Realtek AC'97 Audio
MOUSE PS / 2 mouse
NET 1394 Adapter Remote network engine Miniport (IP) WAN Miniport (PPPOE) Parallel Direct IR Realtek RTL8139 Family PCI Fast Ethernet NIC WAN Miniport (L2TP) WAN Miniport (PPTP)
OTHER DEVICES PCI Modem
PCMCIA Generic CardBus Controller
PROCESSOR Intel Processor
SDHOST SDA Standard Compliant SD Host Controller
SYSTEM Generic Bus Button ACPI resource sixed Button tie / Untie ACPI The system CMOS / real-time clock Direct access memory controller Programmable Interrupt Controller Microcode update device Microsoft System Management BIOS Driver Software Device Enumerator Plug and Play Logical Disk Manager Manager volumes Intel (R) 82801FB/FBM SMBus Controller - 266A Intel (R) 82801FBM LPC Interface Controller - 2641 Intel (R) 82801 PCI Bridge - 2448 Microsoft ACPI-Compliant Embedded Controller Microsoft ACPI-Compliant System Microsoft Composite Battery PCI bus PCI standard host CPU bridge ISAPNP port Terminal Server Device Redirector ACPI Terminal Server Keyboard Driver Terminal Server Mouse Driver System Timer
UNKNOWN PCI FLASH memory
USB Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C Intel (R) 82801FB/FBM USB Universal Host Controller - 2658 Intel (R) 82801FB/FBM USB Universal Host Controller - 2659 Intel (R) 82801FB/FBM USB Universal Host Controller - 265A Intel (R) 82801FB/FBM USB Universal Host Controller - 265B USB Root Hub USB Root Hub USB Root Hub USB Root Hub USB Root Hub
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
I beleive that you had downgraded and installed a retail version of XP by erasing the preinstalled version of Vista in your Notebook.
However, all the drivers required for your Notebook may not be available with HP if your Notebook is preinstalled with Windows Vista.
I recommend you to try downloading and installing the drivers for HP Quick Launch Buttons from the link below for the first Unknown device in the Device Manager :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
Save the file on to the Desktop or My Documents folder and double click once the download is completed to install the drivers.
For the Ethernet Controller, I recommend you to download the LAN Card Drivers from the link below :
ftp://210.51.181.211/cn/nic/INSTALL_VISTA_6208_0922.zip
Coming to IEEE 1394 controller, you need to download and install the Chipset Drivers which are available through the link below :
http://us.download.nvidia.com/Windows/nForce/15.24/15.24_nforce_winxp32_international_whql.exe
Make sure that you download and save the files in the Notebook and double click them once the download is completed and restart the Notebook after installing each of the drivers provided above.
Hope this helps...
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
