Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP Logo
A
Anonymous Posted on May 18, 2015
Water in engine oil.
Don't see a problem with head gasket.
Bill Boyd
Level 3:
Top Expert:
  • Seloc Master 53,816 Answers
  • Posted on May 19, 2015
Bill Boyd
Seloc Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11933902
Points
172802
Water can get into the engine oil from several points
if the engine has a sump oil cooler hen the cooler coil wil be cracked or corroded at the seal points
more likely the housing behind the water pump has corrosion in it behind the impeller and water pressure is making it leak into the sump
2helpful
Engine mixing water and oil in the sump. took the cylinder head and engine block for pressure test. but still mixing what could be wrong. The above was returned as not cracked.
hi there.
Water in the engine - Water can get into your oil sump in two ways: ... Water in the oil- Coolant leak due to non-watertight seal (cylinder head gasket, etc.). If this happens, there is a leak and water is getting into the oil.
Water in engine oil
If you found water in oil car , this water engine car section is for you!
Water in car engine? Water should never be allowed to get into the oil in your engine or gearbox. Otherwise, it will result in significant foaming, dramatically reducing the product's lubrication properties.
  • Water in car - Water condensation in cold air or combustion gases: this phenomenon is extremely rare and only occurs at specific temperatures.
  • Water in the oil - Coolant leak due to non-watertight seal (cylinder head gasket, etc.). If this happens, there is a leak and water is getting into the oil.
Water in motor oil can cause serious damage to your engine - the oil will be denatured and no longer effectively cooled.
Contact your repair centre as soon as possible.
Engine oil in coolant
The 2.0 is notorious for blowing head gaskets. It could be a cracked head, but I bet it\'s the inner side of head gasket. The ongoing problem is caused by putting an aluminum head on a cast block. They just don\'t work together.
My neon will not start replace heads and radiator frist
Signs of a Blown Head Gasket
Note: You can only truly confirm your suspicion by actually seeing the gasket, although precursor signs are usually evident.
Input from Answers.com contributors:
If you see coolant leaking from the water pump, I would pressure-test it and pinpoint the leak and fix that first; oil seepage isn't necessarily abnormal.
Typical symptoms of a blown head gasket may include these: bubbles of air coming up into your radiator (remove cap before starting); a leaking radiator; milkshake-colored oil; overheating; rough running; coolant or oil running from head; spark plug(s) that have a green tint (if green coolant); white-colored or sweet-smelling exhaust.
White smoke from your tail pipe, or loosing coolant through your overflow. Take the cap off and rev the engine: if you see bubbles, or if it comes out, you'll know.
A blown head gasket will leave a dark smell in the radiator. And you will have high back pressure coming though your radiator cap.
Take your car to a radiator shop to have a detector installed: If the blue liquid inside a "bulb" turns yellow, you have a leak.
Beware that if you drive for too long and it overheats, a blown engine will be your outcome.
A blown head gasket can go out in different areas causing different symptoms. Do a compression test to give you some idea. Don't confuse low compression for a bad head gasket, though. A bad valve can lower compression. And a bad ring.
There are lots of clues you can look for. When in doubt and you have tried everything, have the head checked out by a well-established machine shop first, to see if the head was the problem. This way you're not wasting your time replacing the gasket.
My car once had a blown head gasket. I had a great deal of coolant loss. The engine lacked power and ran poorly. It had white smoke coming out the tail pipe. And it overheated very quickly. Also, it had water in the oil.
A quick way to check: Look at your spark plugs; if coolant squirts out, you definitely have a blown head gasket!
Low compression does not necessarily mean a blown head gasket, but it is a good indicator if there is a sharp drop in compression on one or two cylinders, with no drop in the others. Sometimes a blown head gasket will cause a whistling or wheezing sound, but not always. It will not always cause water to enter the oil - or oil to enter the water - but they are signs to look for. Overheating will almost always occur, due to the exhaust entering the coolant. Check your overflow bottle for exhaust smells. Watch for bubbles or overflow of coolant from the radiator while running the engine. Check for muddy gray-looking oil or bubbles on the dipstick.
Often (but not always), a blown head gasket will also cause deposit of water on a piece of cardboard held an inch from the tailpipe output while the engine is running (when this is happening, it is likely that the catalytic converter has been ruined and the muffler will corrode in short order as well). Sometimes drops of water will be seen dropping from the end of the tailpipe.
Another clue: Turn on the heater; often when the head gasket is blown an odor of antifreeze and synthetic rubber will emanate from the heater vents.
Many of the symptoms of a blown head gasket can be caused by some other problem in the cooling system, without the head gasket being damaged. Conversely, other problems with the cooling system can cause a blown head gasket and/or warped head. For example, a corroding radiator can send chunks of rust through the cooling system which take out the thermostat and water pump. If the thermostat is old, sticking and corroding, it can send those chunks through the system and take out the water pump or cause a blockage in the radiator, etc.
Radiator leaks can be the primary cause, or a result, of failures in other cooling system components.
Don't keep driving with the car overheated, especially if your engine has an aluminum head; you are likely to warp it. If it is warped beyond a certain tolerance, it cannot be planed and will have to be replaced when the head gasket is replaced.
One of the most common tell-tale signs is a milky-gray ring around your oil cap. When coolant enters the engine oil through a crack in the head or through a blown gasket, it evaporates and leaves a milky ring around the oil cap. Another easy way to tell is to check your oil dipstick. Change your oil and pull out the dipstick. Make sure that you take note of how far up the dipstick the oil is. Top off your cooling system and fill your cooling reservoir to the top. Screw radiator cap back on and start engine. Run engine for about 20-30 minutes or until it reaches normal operating temperature. Allow engine to cool (engine must cool completely to get accurate oil reading). Check oil dipstick again. If the oil has a watery appearance and has risen noticeably up the dipstick, then you probably have a blown head gasket or a warped head. Also, look for a sweet-smelling liquid coming out of your tailpipe. Any of the above symptoms could be the result of a blown head gasket.
The easiest way to tell is with a compression meter. This replaces the spark plug and lets you know what compression each cylinder is running at. If your compression is abnormally low, then you have a blown head gasket or a warped head. (Note: check the repair manual for appropriate compression of each cylinder.)
This can be detected in a variety of ways: One way is to note whether that part of the engine block is leaking fluid. This is difficult to determine since there are many other parts of the engine nearby that can also leak fluids, especially when a vehicle is parked in one place for more than a few hours. One of the best indications of a blown, or nearly blown, head gasket in most automobiles is when the cooling system appears to be malfunctioning. The cooling system's efficiency and performance can be directly affected by the quality of the head gasket.
If your radiator is getting low on water often, this is a sign. The water could be discharged through the tailpipe on your automobile. Another sign is if your car motor has a miss in the engine. The water could be going in on top of the cylinders. This will foul the plugs and cause it to miss.
There are a few simple indicators you can check for with the engine cold and not running: 1) contaminated oil - it will have a milky appearance from the water mixing in the oil 2) oil on the top of the coolant inside the radiator (if your vehicle has a remote header tank you may not get this); 3) Have someone crank (remove the coil lead or disable the electronic ignition) the engine on the starter with the radiator cap or coolant jacket bleed hose/bolt removed. If the coolant pulses up and down or blows bubbles, you could be in trouble. If you find any of these symptoms move on to removing the spark plugs (label the plugs and the leads as you remove them, so you can put them back in the same place) and again crank the engine on the starter. Depending on how badly your head or gasket is gone, you may get coolant or oil coming out of the plug holes. Inspection of the plugs will also reveal problems during combustion: if you have rusty flaky deposits on the plugs, you may be burning off water; and if you have a heavy carbon, you are burning oil. If you have any of the first 3 items listed (water in oil, oil in water, or pulsing coolant - but don't get any result from checking the plugs) change the oil and water as appropriate, then warm up the engine without the radiator cap on (or the bleeder hose/bolt) and watch for bubbles as the engine warms up. Put the cap back on the cooling system and take the vehicle for a short drive, or run the engine till the entire system is up to temperature and then check the oil for contamination. Having these symptoms is not always indicative of a blown head gasket; usually if the gasket is gone, there is going to be some warping of the head and or block of the engine.
Loss of engine coolant with no external leaks, a continuous stream of bubbles can be seen with the radiator cap off, black gummy and sometimes crusty stuff around the radiator
Several common signs of a blown head gasket:
Blue/white smoke coming out the tail pipe which indicates oil is burning
Dripping oil from the gasket itself
Carbon Monoxide or hydrocarbons in the cooling reservoir
Excessive coolant loss with no obvious source of leakage
Loss of power or a rough engine due to compression loss
Water mixing with oil
Oil mixing with water
Low compression in 2 or more adjacent cylinders
Remove dipstick and let a drop of fluid fall on hot part of engine - oil will smoke water will "sizzle"
Going through alot of oil and antifreeze.... have oil where my spark plug is
The engine can burn alot of coolant before you see any smoke.
And having a cooling leak in the engine could cause it to run hot at times.
If you are adding coolant every week and don't see any leaks, the engine has to be burning it. Most of the time it is a blown head gasket and cracked head or block.
Oil is mixing with water but does not have a head gasket problem any ideas please
I don't mean to sound sceptical, but how have you concluded there is not any head gasket problem? Do you mean a compression test is good? Because that will not show up any leak between the water jacket and the oil passages, via the head gasket joint. Only a pinhole leak is needed because water is, well, watery.
Has a radiator leak down test been done? This will show up water jacket leaks (there may be more than one), and give you some idea of the size.
http://www.benplace.com/pressure_test.htm
I don't know your engine well, but I cannot think of another ready way for water to get in the oil or v-v, except a cracked block, which is rare. I have read of a leaky intake manifold gasket causing it, but I can't picture that one myself.
2answers
I have a growing head gasket proplem, hole into the coolent and oil now, can I use the blue devil sealent to fix it?
when the water mixes with the oil , if you don't fix it right away , you can warp the head or crack the head or engine block.
1helpful
1991 toyota pickup, overheating problem, there is water that I know getting into the oil. I just bought a new head and gasket plus the timing cover gasket as well. ran it today and still blowing water in...
Coolant or water in the oil can be from a head gasket leak, but it can also be an intake manifold gasket or a crack in the block or head etc. I would begin by removing the spark-plugs and then pressurizing the cooling system and checking each cylinder for signs of coolant entering them. If the cylinders stay dry and coolant goes into the oil during the test you most likely have an intake gasket that's leaking. Don't run thee engine with coolant in the oil or you'll have catastrophic damage!
Have 1987 Chev Silverado, drove 500 feet & oil pressure gauge went to max???
You have a clogged oil system or a faulty pump or possibly the wrong oil in the motor. This usually happens when the oil filter clogged for some reason. Check the oil for water contamination. If you have water in your oil you have one of several conditions. Cracked Head, Cracked block, blown head gasket or one of the retaining screws for the timing chain guide has come out and it is allowing water into the oil. You won't know exactly what the problem is until you get the engine opened up and locate the real problem. If you don't find a problem with the head gasket pressure test the head and magna flux the cylinders.
3helpful
6answers
Water getting into oil
If its just condensation in the oil cap or dipstick, to some degree its normal. However if you have water in the oil and its very creamy in texture, its probably a head gasket leak, or cracked head. Its important to get it repaired soon, or total engine bearing failure will result.
Top Seloc Boating Experts
jws1013
ADMIN Andrew
ADMIN Andrew
Are you a Seloc Boating Expert? Answer questions, earn points and help others
