Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Code 88 is for the fuel pressure being too high.
Code 251 is for a problem with the fuel volume / quantity sensor which measures the amount of fuel in the line.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
CD251 No JPEG board mounting at JPEG board mount setting • JPEG board (Scan Accelerator Kit) is not mounted when the JPEG board mounting is set ON at Service Mode.
so you need to buy the jpeg board or turn off the jpeg setting in service mode. if you need help with that contact me...
