Someone pulled plug wires off i need to no how they go back on
What model
Case VAC engine
http://www.tractordata.com/farm-tractors/006/4/3/6437-ji-case-vac-engine.html
The firing order is ( 1 - 3 - 7 - 2 - 6 - 5 - 4 - 8 )
The distributor rotor turns COUNTERCLOCKWISE
The marked # 1 position on the distrubutor cap faces to the REAR and slightly towards the drivers side
The engine cylinders / spark plug locations are numbered :
firewall
4 - 8
3 - 7
2 - 6
1 - 5
front
If someone has altered the disstributer, pull #1 plug, put finger over hole, turn engine over until compression on that cyl, line up timing marks (ball park only) and rotor will be pointing at the correct terminal for #1 cylinder plug wire connection, in the cap.
