Televison & Video Logo
j
jayne Posted on May 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Led flashing television not responding to remote
New tv was working and change to new room.now led flashing and not responding to remote.luxor 3d..modle number ..luxo142001/02
johnny rebel
Level 3:
Top Expert:
  • Luxor Master 10,875 Answers
  • Posted on May 16, 2015
 johnny rebel
Luxor Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2939503
Points
47944
Return for warranty repair
Testimonial: "thank you for advice....fast response"
I have Luxor 55in TV. The red light that works remote has gone where do I buy new one please?
Question edited for clarity and spelling.
The red light on your television is nothing to do with the remote, it is just a standby light. It is a small red LED. The most likely issue is the batteries in the remote. Here is a trick. Use a smartphone with a front facing selfie camera. Point the remote at the phone and press any of the buttons. On the camera screen you should see the sensor on the front of the remote blink red. If it doesn't, change the batteries and try again.
Luxor tv goes on and of new tv
Contact the authorized service center as a new TV will be under warranty. Gopakumar Gopalan Google
1helpful
Luxor LED550FHD Wont start
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
My kv24fs120 remote is not working will not change channels
The remote by itself can be tested for free by any shop (a tester will check any or all buttons)>
Also a digital camera in a very dark room with remote pointed at it will respond with a faint flash on its display screen when buttons are pressed on the remote---either the remote or ?
2answers
Menu controls
sometimes pressing either both channel or both volume buttons willl get you in the setting
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
I neid go know how to reprogram one of the controls for the tv in a room but i lost the control for the tv in my living room, in the living room i have the cable box.
jc4lifes3as
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
2. Press and hold the TV Power button for three seconds until the LED flashes.
4. Press OK. Note: The LED will flash three times.
Power Scan:
Remote: Basic Remote (Television Only)
3. Press and release the TV Power button.
4. Press and release the Up or Down Arrow on the remote until the television turns off.
5. After the television turns off, press and release the OK button.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network"
TV IS AN ORION TV/VCR COMBO. THE BEDROOM TV IS IN RUNS OFF THE LIVING ROOM RECEIVER. THE TV CHANNEL IS SUPPOSED TO BE ON 60. NO REMOTE 4 TV, TO CHANGE CHANNEL TO 60. TRYING TO PROGRAM DISH REMOTE. 1 CODE 4...
zassyway
I have provided instructions on how to program the remote to your TV. I have also provided codes for your TV brand.
  2. Press and Hold the TV Power button for three seconds until the LED flashes
The codes are as follow: 720, 220, 748, 721 (694 only has a 2% success rate). I hope this helps.
Ray Calo
DISH Network
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
Remote Control not working
you can easy check if you existing remote really work just look on the IR led with a digital cam and u will be able to see the led flashing
Top Luxor Televison & Video Experts
Paul Bade
NOEL
NOEL
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
