SOURCE: I need an owners manual for a cub cadet riding
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
SOURCE: i have a cub cadet model 3 1042 it starts but
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: I have a cub cadet
There is a wire shorted to ground (metal) somewhere...check all the wiring for a bare spot somewhere... this is causing the short...repalce the wire and you will be good...
finding the bad spot is the hard part...
heatman101
SOURCE: my cub cadet 1042 leaves a stip down the center
I had the same. design of the deck is not good. grass will build up and insolate (like a donut) the blade from cutting the immediate blades. FIX - replace custom blades with "Gator Blades and the claws will free up the cluster of interferances of grass, kick it out, thus allowing the blade free space to cut the immediates blades of grass.
Hope this helps as it was my last trial of fixes. IT DOES WORK.
J THOMAS
SOURCE: Cub Cadet LT1042 PTO
you only need to remove the center bolt but make sure you see where the pins that keep it from spinning go this will help put it back togeather
wow 15 volts that's a bit too high ,and with the fuse blowing tells me something is already affected by that higher voltage that's not good . id look real carefull at all your grounds Both ends of cables and under all the screws and bolts (rust) that are used for it , a loose or bad connection to ground will sure cause a symptom that your describing
