Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Black will print properly only on "High" Print setting
His problem started suddenly, after I had printed a page with a completely dark banner on the top.
On "Standard" setting, the text lines don't print completely, and some completely disappear. Sometimes the first few lines print properly. However, on "High", the printing always looks fine (if a little bit faint).
I have tried the following: Doing the Mmaintenance functions, including "Cleaning" and "HeadRefreshing", replacing the cartridge, and blowing gently on the hole at the top of the cartridge to expel some ink. None has solved the problem.
Thank you for any advice.
  • Henry Smith Nov 14, 2007
    I don't see why a hardware problem of this type would suddenly occur on a printer that is not very old.
    One of the free posts suggested soaking the print head in rubbing alcohol to clean it. I could try that, but how would I remove the print head from the printer?
    I would prefer a proposed solution I can try myself, without taking the printer for repair.
  • Canon Master
  • 1,113 Answers
Are you using gen.Canon ink? Try new inks if this is not the problem then only other correct option is to replace print head.
head purchase...
http://www.precisionroller.com/find/canon+mp390+print+head+printhead+multipass+multi-pass+mp+390.htm
head removal
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9722
Posted on Nov 14, 2007
  • 1 more comment
  • Soulvisitor
    Soulvisitor Nov 14, 2007
    I think that the dark banner used up most ink in one cartridge, the colour ink contains 3 colours and 1 can run out before the rest requiring replacment of cartridge.
    I have seen these run out of black and make black ink via colour cartridge mixing all its colours to print in black.
    First step is replace c0olour cartridge, then black then head.
  • Soulvisitor
    In head removal link you will need to type in remove print head in FAQ section
  • Soulvisitor
    Soulvisitor Nov 16, 2007
    What Happened??
    Sergeant:
    Champion:
  • 306 Answers
After all the trouble shooting you have done their most likely a hardware issues causing the problem.
Please Contact Canon for repair service or replacement.
1-800-828-4040
  • Anonymous Nov 14, 2007
    well all the solutions that can be provided has been given, Did you contact Canon on the number provided to at least see what there response was?
6ya staff
SOURCE:
P50 dose not print black color
You might have to run the head clean more than once - if no black at all is printing.. Alternatively, set out a page of all black (background) and print few pages on high print quality setting.
good luck!
Feb 17, 2015 | Epson P50 Inkjet Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Printing a spreadsheet
You should tell us your "Operating System, Spreadsheet Program and Printer" for us to give you a difinitive answer. Whithout this info I will attempt to give you a general answer.
In your spreadsheet program, go to "File" and select "Page Setup" and set your paper size and set your margines and Portrait/landscape option. Your spreadsheet display should show you the paper limits for printing each page. Adjust the columns to the paper size. Highlight all the columns and rows you want to print. Find the menu option to set print area and click it. Now the computer will send the paged information to the printer and print as many pages as needed to cover the print area.
May 31, 2009 | Apple Office Equipment & Supplies
My lexmark X5495 always prints banner
Not sure which OS, you're using, but try this:
Go to Start > Printers > right-click your PDF printer and go to Properties
Go to Printing Preferences and ensure in all possible locations there that you don't have "banner" selected.
Jan 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Print quality suddenly degraded
Sounds like your print head went bad. You will have to buy another one.
Jun 04, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Prints black page
Click Start - All programs - HP - HP Director/Solution center
Click Settings - Print settings - Printer settings
Click on the Colors. In Color Management select "Managed by Application". Click Apply and OK. Close HP Director/Solution center.
Try printing.
Jan 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Banner printing
got to be a setup problem. in your printer program there is a page for margins, page breaks. set all for zero or disable page breaks. as far as vista goes, personally I never liked it. I am running firefox and have been for the past three years. It doesn't have all the problem back doors like windows internet explorer. rarely do I ever get patches for the program - it just don't need them.AND firefox is completely compatible with 99% of all running programs.
Sep 11, 2007 | HP Photosmart 2610 All-In-One InkJet...
Deskjet HP 6940
this might be a software problem also. please specify which software you are using to print these banners. Thanks
Jun 12, 2007 | HP Deskjet 6940dt InkJet Photo Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
197 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
