SOURCE: no dial tone
plug it back into the base and wait till the lites flicker for a sec... remove it and try it again.
Robert
SOURCE: Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
SOURCE: No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
SOURCE: no dial tone on other 2 handsets.
some one had the solution and it was so simple,all i had to do was to take the two handsets,and put them on the base for only a few seconds.thank you so very much. i was ready to take them back for a refund.again thank you.....
SOURCE: No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
