sounds like a small capacator in the main circuit has blown its better to buy the circuit board I bought one last week and it cost 37gbp ie stirling,go to bosch dishwasher circuit boards.com.adrian....
For a detailed Dishwasher illustration, click below.
Built in Warning!
To avoid personal injury or even death, always disconnect your
appliance from its power source--that is, unplug it or break the
connection at the circuit breaker or fuse box--before you do any
troubleshooting or repair work on your appliance. Also, because some
components may have sharp edges, use caution while working on your
appliance.
Does Your machine have a little switch button activated by the top door? (You can hear it click as you open and close the door.). If that switch is not working, the control click can not let the machine advance to the next step in the cycle.
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
Can you manually rotate the timer control to the next steps? Will it proceed thru the cycles when you rotate the timer manually? If so, then you can complete the cycle manually for the time being... If so-- then the clock motor that drives the timer.control is not advancing it.
If yours is a newer machine with all digital controls, then I suspect something wrong in that controller, too-- But I do not have any idea of how to 'advance it manually! (The blessings of modern controllers!-- Give me the old clock motor driven drum controllers! :-) )
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
