The printer says "unable to clean see trouble shooting and routine maintence chapter in user's guide
You should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge
counter is already full. Please refer below for the instructions on troubleshooting
your machine.
1. To enter MAINTENANCE Mode: Press
MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the
following:
a. 8 then
press SET
b. 0 then
press SET
3. Using MONO START, just press it until
the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the
following:
a. 2 then
press SET
b. 7 then
press SET
a. 8 then
press SET
b. 3 then
press SET
This is to reset the purge
counter. Then press stop/exit
5. Using arrow up button look for the
following:
a. 0 then
press SET
b. 1 then
press SET (To reset unit)
a. 9 then
press SET
b. 9 then
press SET (To exit Maintenance mode)
after deep cleaning printer still not working what should i do?
