The battery is too discharged to start the tablet.
If you have connected it to a charger and it does not vchange the icon to show it is charging then either the charger is no good or the connector on the tablet is broken.
If the connector is broken, buy a new tablet.
If the icon changes when you try a different charger, then you have the answer.
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
SOURCE: i dont have a hdmi on my mach speed trio steath g2 tablet can i hook up to the to watch nexflix
You should look at a Google Chromecast.
This is an HDMI device, that you can stream from your android to the ChromeCast connected to your TV.
They are actually quite cheap to purchase.
Then you use your tablet to control it.
It should also work with Netflix.
I don't know much about them but I had the same problem with another tablet. Try keeping you finger pressed against the screen when you restart it for about 20 seconds max. It may work.
SOURCE: I can not open my jlab tablet I forgot the lock pattern, what do I do?
Just do randem paterns
SOURCE: How do I get back into my jlab tablet I can't remember my lock pattern?
Ok just try rAndem patterns
