Sorry, you have to use a computer to jailbreak your iPod touch, only iPhone can be jailbroken without a computer. And here is a guide about how to jailbreak iPod.
How to jailbreak iPod touch for free and safe
There's the only other way to do a JB: to buy other equipment to hard-program your device. Why don't use PC?
SOURCE: 8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
if you need any further help let me know.
Good Luck
SOURCE: my ipod is frozen
Warning: This should be used as a last resort, restoring will erase all of your data
*Must have iPod plugged into computer while doing this*
Be patient, the force restore part may take up to 20 seconds.
1. Press and hold the home button and the sleep/wake button. (the power off option will appear, ignore it)
2. When the apple logo appears let go of the sleep/wake button (keep holding the home button.)
3. After a few seconds you should see the connect to iTunes image (you can now let go of the home button.)
4. Open iTunes .
5. iTunes should automatically recognize your iPod once the image comes up, if not unplug your iPod and plug it back in.
6. Restore your iPod by clicking the "Restore" button.
If iTunes comes up with an error you may want to try
a. Uninstalling and reinstalling iTunes or
b. restoring on a different compute
SOURCE: my ipod wont connect to wifi at my house but will at restaurants.
i have that problem with mine sometimes try uninstalling the network and reinstalling it on your ipod , it should find it again, if that dosnt work try a soft resetting the router, once the router has booted up try and get into the network again good luck !!
SOURCE: usb arrow points to itune
Unfortunately you put your device into whats called "recovery-mode".
The simplest solution is to plug the device into itunes, restore the firmware (itunes will ask you to do so) and start over. It will delete your ipod, but afterwards youll be able to recover most of your stuff from the backup itunes makes.
This problem occurs if you dont follow the redsnow commands exactly. when it asks you to put your device into dfu mode, you need to push the buttons in the order and for t he amount of time that it says on the screen.
SOURCE: is my iPod touch bricked? It is unresponsive
try using blackra1n by geohot for 3.1.2 firmware restore through itunes with holding shift and restore
Testimonial: "thanks!"
