If you have discs for all,pull out the hard drives,buy new ones,reinstall them then reboot with your discs,if you dont know how to do it,ask a teenager,they know everything about computers,make a couple good passwords,with numbers and letters,never type a complete word"like,n2w4w6y8o0r2k4y"newyorky2468024,all together,change them every 30 days and have someone teach you how to stay safe from hackers,do not download anything that someone asks you to download,only download things that you search for
SOURCE: Dell Laptop with XP keeps dropping connection
find the manufacturer/model # of your wireless adapter and download the latest driver from dell's website (you can go to support.dell.com and enter your service tag/laptop model # if you want).
SOURCE: low signal(wireless MAXg ADSL Gateway USR9108)
1.TRY siting in a place wth less people ... actually wth my USR9108 i get disconnected even if some one is standing infrront of the modem so stay in a open place wth less people.
2.RESET your modem 3 tymes and configure ur modem by the settings given from the Telecom company.
3.Check ur modem antennae ... bcoz its modem is very FRAGILE... it sometimes have an internal wire break ,,,,
TRY installing ur BRothers antannae on ur modem nd den use it....
ALI KAZMI
SOURCE: very low signal (wireless maxg adsl gateway usr9108)
Have you tried changing the channel? This might help icrease your signal aslo avoid putting it near wall and if possible put somewhere higher (5-10 ft above the ground)
SOURCE: my N1 vison keep losing on wireless connection
If you have a 3G phone in the house, It operates at the same frequency and is a nono.
If not I would suggest you completley rest modem and re-enter U/N, P/W etc and set up secure network also. If still a problem, maybe faulty modem.
SOURCE: WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
