Here are a couple of things to check. First look at the back inside wall of the freezer and see if it is getting coated with frost or snow. If yes, you probably have a problem with the defrost system usually the defrost heater burns out first. Once you replace the heaters, all the excess frost has to be melted off the cooling coils behind that wall. A hair dryer works well for this. Another thing t check is the fan motor that is back behind that same wall. If the fan stops for any reason--- you loose cooling on both sides.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
