SOURCE: LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
[email protected]
SOURCE: colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
SOURCE: i just bought a 52 inch samsung my volume does not
Did you try another time warner remote if yes then this is normal because if on/off works that means the volume function is not coded for the time warner remote because the set is to new.
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
