Master
- Posted on May 08, 2015
Re: What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
- Press Menu on the control panel until Maintenance appears on the top line of the display.
- Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
The first available menu item, Paper Setting, displays on the bottom line.
- Press the scroll buttons until you see the item you want to clear.
- Paper Setting: Restore all of the Paper Setting options to the factory default.
- Copy Setup: Restores all of the Copy Setup options to the factory default.
- Fax Setup: Restores all of the Fax Setup options to the factory default.
- Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
- Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
- Sound/Volume: Resets the sound and volume settings to the factory default.
- Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
- Set Report: Clears all records of your faxes sent.
- RCV Report: Clears all records of your faxes received.
- Phone Book: Clears the speed dial or group dial numbers stored in the memory.
- Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
- Repeat steps 2 and 3 to clear another item.
ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
