Try to put it on the lowest torque and if it slips when wanted, then add a little more torque and check to make sure it slips. Continue at each torque setting and usually works again at full torque. Usually happens when left on the same torque all the time. This kind of resets it.
Testimonial: "Thanks will give it a try when i have a few minutes spare."
SOURCE: Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
SOURCE: Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
SOURCE: i have an 18v dewalt hammer drill dc925 and cant
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
SOURCE: when in drill mode the tork still kicks in on my dewalt
there is a gear and a clutch as agier said in the head. if its old it looses its catch, youll need to take it apart and look at it. the torque setting just tightens on the head the more you tighten it the less it will give( the ratcheting you hear when you set it low) .expensive drill so its worth trying to fix. how old is it? as for drilling thru knots and hard wood make sure your bits are sharp, you can spend alot of time trying to drill with a dull bit. do you sharpen your bits? i do alot of drilling with battery drill thruout the year and believe me a sharp bit is waaaay easier. though ive never had to sharpen concrete bit because they always break when they get old and i buy new.
so your saying it stops completley when you hit something hard, right. does it ratchet?
Thanks to all for the help.
