Support site has phone number under contact
http://www.evenflo.com/Products/Evenflo/Car_Seats/Platinum_Symphony_DLX/
Evenflo Baby Car Carriers Platinum Protection Series
SOURCE: Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
SOURCE: Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
SOURCE: Putting the car seat back together
also try this official manual:
http://www.babyage.com/icons/localhost/products/multimedia/26078_3591328.pdf
SOURCE: evenflo discovery 5 infant car seat straps
Okay okay--do not do anything with the big pieces behind the babies back but the gold clips at the **** area..pop those out and shove that piece and the clip and the chest clip through the back of the strap hole--then reput the strap through the slot you wish then the gold pieces back through the bottom and of course pop the gold pieces back--again do not use the upper clips behind the back to do this :0)
SOURCE: i need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
