are you seeing several wireless signals from others in neighborhod that is strong overlapping signals
is your phone near it
wireless keyboards ,wireless mice, ipod , ipad, home phones,wireless remotes, wireless speakers
look for other sources of interference too
does it always happen at a exact time or action.
raise the router up some to blanket the area only a few inches might be necessary.
does it do the same dying everywhere in house or on road
you can set a new default channel in your wireless thats less used in your spectrum its kinda easy but several steps an logins
Sometimes the wifi connections get messed up. Try quitting all apps, turn the iPad off and restart it. You may want to do this with the units connected to the internet cable as well. You may have to delete the connection and reconnect from your iPad, too. Good luck...
Hi Tina,
The problem could be a crashed or hung application. Depending on which version of iOS your running what you might want to try first is to see if the game is still running in the background;
Double click the bottom button on your iPad
Then you will see all the applications which are open
Close all applications just to be safe
Then try your game again.
If it still fails then after doing this turn the iPad off completely.
You do this by;
Pushing the power button (top right of the iPad) for 10 seconds
then slide the slider to Power Off. Let it shut down completely. After about 60 seconds turn the iPad and try your game again and see if it works.
If this still fails, you may have to check if the App Developer has released a newer version. But likely the previous solutions should resolve your problem.
I have similar problems with my Targus keyboard connection to ipad w/ ios 7, but not yet found solution. In my situation, connect can only be made after a complete power down. Keyboard is on; Bluetooth is on; iPad says it has discovered and connected to the Targus Versavu Keyboard, but keypad does not respond.
If the iPad is frozen and can't be restarted the normal way,press and hold the sleep/wake button and the home button together for at least 10 seconds.The red slider may appear and the screen may dim but don't release the 2 buttons until the apple logo appears.If this doesn't work,you will need to backup and restore the iPad.Upgrade to latest version of iTunes,then connect to computer and select it when it appears under devices.If you haven't done a sync do so now.Click summary tab and then restore.If you haven't done a backup you will be prompted to do so.This will backup all settings on iPad..Next click restore and if you have completed all steps,wait until iPad completes the restore and returns to home screen.
