Police Mens Raptor, Black and Gold-Plate, Rubber Strap 13092JSR/02 Watch Logo
A
Anonymous Posted on May 05, 2015
I bought a Police watch last year but I need another one ,where can I find it?
I bought one last years ,but I need another one ,I couldn't found in Dubai ,please assist me where I can found
A
Anonymous
2answers
I have a Gucci watch which cost £630.00 and the battery lasted 17 months, is that the usual life span for a battery
it can be--their is no definite life span of a battery because everything has a different draw of power a simple watch can last years while more complex such as date/stop watch /backlight etc will draw and kill battery quicker
I just bought a police kickers timepieces watch i dont know how to set the day i've tried hundreds of time but its not working can some one help me !!
Since you have stated ABSOLUTELY nothing about provinance... model, year... owners manual POLICE being a pretty decent watch from the UK (I'm going to skip right on past the AUTHENTIC notion... Chronograph (shown).
If your your watch is a REGULAR knock-off (replicant)... t has the miyota movement...
A highly precise and reliable motor
in it's own right.
(sets very much like the high end valjoux cousins)
It is a crown-set... typically a three position stem set.
Force nothing... !!
Some GENTLY unscrew the crown... others will pull out
to set: 1, TIMW 2, DATE... THREE (back to normal -closed).
In the closed position
The stop/start butons do precisely that on those SUB-DIALS.
In the SET positions the start/reset buttons are used to ZERO those sub-dials (press & hold... then individual clicks will move each hand to zero).
Hope this helps!
http://www.bing.com/search?q=watch%20valjoux%20quartz%20movement&qs=n&form=QBRE&pq=watch%20valjoux&sc=0-13&sp=-1&sk=&cvid=607E5483C971481BBCFF824956E6A0D7
police quartz movement Bing images
2answers
NEW STRAP FOR 11299J POLICE WATCH
Barry, It is more and more common these days for a watch to have a unique band, unique unto itself. The only way some bands can be purchased is from the manufacture or seller which I presume is Shop NBC. Call them. I actually couldn't find your specific watch on the site but unless it is a watch with the "traditional lugs" you will need to go there. Michael
Nov 07, 2011 • Watches
How do I replace the battery on my watch, I bought it about 5 years ago and have never use it
you have to bring it to any watch service center, you may not have use it but the battery inside is continously working for years and you found out now that it has stops, you had to bring it to service center to avoid much bigger problem with your watch.
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Where can i get my police watch fixed in scotland.The winder off the side is missing.
The part will need to be put on order with police and you will need to consider if you want the watch tested for water resist.The wtch repair centre have a store in East Kilbride and Glenrothes their details can be found on www.rolexrepairs.co.uk
Regards
2helpful
2answers
How to replaced a eco drive battery
The ECO series of Citizen's do not require battery replacement, as they are solar powered. If the watch stops due to a long period of non-use, there is a procedure in the manual as well as the Citizen website on how to get it running again. You will have to expose it to light for several hours (but not with lots of heat such as a car dash) to get it running. If you continue to have trouble, you may have a problem with the watch. I bought my wife a ladies ECO drive about 8 years ago and bought one for myself about 2 years ago and have not had a bit of problems with either. They are extremely good watches and it is nice not to have to worry about "when will the battery die?"
Replacement watch batteries
When you buy your watch the manufacture puts in a battery that is made to last 5 years so that the watch can sit on the shelf and not need the battery changed before you have even bought it. Batteries you buy from a store or a watchrepair usually last about 1.5 years. Sometimes you can find a watchmaker who carries the five year batteries, but most people don't want to pay the $25-$30 to have it installed so most places won't carry them for rear they will never sell.I would also tell you NOT to buy your batteries from a grocery store or a Wallgreens type place because those batteries could have been sitting there for months, or even over a year. If you go to a watch repair they go through so many batteries that almost evey time you are getting a fresh battery.
Oct 21, 2008 • Watches
Top Police Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Police Watch Expert? Answer questions, earn points and help others
