Sony up890md thermalprinter testprint ok scane print notprinting only plain white papercommingout
SOURCE: Problem While printing
Hi there it seems to me that you have the printer driver set incorrectly.
First on the computer click on
Start
Then Control panel
Printers and Faxes
once in there right hand click on the pinter and select printing preferences.
Select the tray you wish to use as your default. Ok and exit that.
On the printer press the green tick button move the up or down arrow until paper handling is displayed. Select which feed either cassette or MP then sizes for this tray. Once that is complete select what media type the paper is i.e. plain preprinted or others.
(You may have to do that in the printing preferences within the driver as well)
That all going well you should now be able to press the print button and the page will come out from where you asked it from and with out pressing any buttons.
Hope this was of some help.
J
SOURCE: Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
SOURCE: HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
SOURCE: won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
