Televison & Video Logo
Posted on May 04, 2015
How do I connect a Emerson TV to a Magnavox DVD?
Need directions & what cables needed in order to connect an Emerson LC320EM3F-A TV to a Magnavox MDV2100/F7 DVD player.
A
Anonymous
You will need either an S-Video connector and two RCA connectors, or three RCA connectors. Use either the S-video connector or one RCA connector to connect the video, and use the two RCA connectors to connect LEFT and RIGHT audio. Done.
2helpful
I have a Emerson model LC320EM3F-A TV style ME2A1236181115. The model number for the Magnavox DVD Player is MDV2100/F7. How do I get it to work?
I agree with other post, but look for color such as yellow/red/white connections composite or green/blue/red for video and red/white for audio or even if there is an HDMI connection on DVD player and correspond them with the same color wires to the TV corresponding connections then on TV remote look for a button marked INPUT or SOURCE and look at where u put the wires on the TV and select in that menu. Hope this helps if this was what u were trying to do. Thanks
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Dish network code for emerson LC320EM3F
For LC320EM3F I used 694. I read somewhere that Emerson makes Funai TVs. This was listed as one of their codes. Worked like a champ.
2helpful
2answers
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Magnavox DVD/VCR Dual
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
1helpful
2answers
Spencers jumbo remote
The Emerson DVD code work work for Magnovox. (I used 447) I figured this out since I have both DVD player and the one remotes always interfers with the other.
2helpful
5answers
Emerson jumbo remote
snowlady: You probably got it already but if not, here ya go:
Magnavox TV: 004,008, 009, 069, 074, 075, 077, 089, 163, 165
Matthew: 173, 183, 198
ronnmelplus4:
RCA TV: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, 194
RCA VCR: 000, 003, 021, 055, 060, 082, 083, 084, 086, 087, 088, 089, 090, 091, 107, 110, 115, 120, 125, 134, 137
Emerson Combo: My book doesn't list Emerson, only JVC, Philips, Sansung and Sanyo
Hook up
connect yellow white and red cables FROM AUDIO/VIDEO out from the dvd player to the tv. connect your cable wire or coaxial cable to this unit. (the first one is going to be on your tv disconnect that one and put it on this unit where it says ANT IN.) connect the cable that came with it on ANT OUT or a cable that you might have and then turn on tv. and use your original remote to your television and look for a button that is regarding input or tv/video or tv/av. This function will only be on your tv remote. NOT DIRECT TV.
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
