Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Posted on Jul 10, 2009
Mower deck not running
I was mowing with my Husqvarna model Yth2448 and the mower assembly quit running. I checked the belts and cleaned the mower assembly--but that was not the problem. I went to my local repair shop and they said it was probably a relay switch, which they sold me. They told me the switch could be found by tracing the wires to the engine. I have done this and looked at schematics of the engine and cannot find a relay switch. Where is it or did they sell me something I didn't need????
  • daledebco Aug 05, 2009
    Thanks--
    Already did that--they were wrong--no relay switch--clutch was the problem--is being repaired.
Anonymous
Level 1:
  • Contributor 11 Answers
  • Posted on Aug 03, 2009
Anonymous
Contributor
Level 1:
Answers
11
Questions
0
Helped
90319
Points
40
You model requires a clutch switch not a relay switch. take it back and bring them your manual on the tractor and help them find out what you need.
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
Ignore previous message - Belt that operates my mower blades popped off. Looking in my manual it appears diagrams for the belt is missing. Anyone have something to help me get this thing back...
I had one, the deck belt routing diagram was not only in the manual, it was also on a little decal attached to the top of the deck. A google search goes a long way, check for AYP and MTD websites as they make about all the mowers, regardless of the label on them.
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
I have a YTH2448 Tractor that overheats
Although blockages in the shroud and cooling fins are the most common cause of overheating, a small gas engine can also overheat if the fuel-air mix is too lean. Are you sure the carb overhaul kit had the right parts, and is there any possible of adjusting the mixture? Here is a set of parts diagrams for your tractor - Engine-2 has the carburetor-related parts. Good luck!
My lawnmower quit mowing.
It depends on whether its a lever or pushbutton engage model? it may be a broken belt or a simple wire connection come loose. If you want to stay friends tell them mowers are repairable/replaceable but friends arent!
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
