Garden Logo
Percy Thomas Posted on May 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my Ryobi weedeater stall after starting when I adjust throttle?
Eugene Rounds
Level 3:
  • Ryobi Master 1,169 Answers
  • Posted on May 02, 2015
 Eugene Rounds
Ryobi Master
Level 3:
Answers
1169
Questions
Helped
592878
Points
4432
Most likely the fuel mixture settings are off.
Dillard s Bearden
Level 2:
  • Expert 41 Answers
  • Posted on Nov 08, 2018
Dillard s Bearden
Expert
Level 2:
Answers
41
Questions
0
Helped
12948
Points
143
Yes you need carb and filer
Gary starling
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
Gary starling
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
7258
Points
9
When you say adjust throttle do you mean pulling the finger Trigger or you talking about the fuel mixture settings on a carburetor
2answers
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
1helpful
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
I have Ryobi weedeater that has a new Carbuerator,getting gas to the cyl.an has good fire to the plug an will not start need help bad
Make sure u r not getting to much fuel. With switch off pull string twice then turn switch with throttle cable helded wide open try to start.good luck.new dose not mean adjusted good luck
1helpful
Probglem:Machine would run for 15-20 seconds and
i had a similar problem last year. finally took it to a repair shop..they replaced the diaphram under warranty. seems to be ok now, though i am not overly impressed with this machine
2helpful
I bought a Ryobi RY34420 yesterday from home depot
Sounds as tho it needs a minor carburetor adjustment. It's not getting enough fuel when you pull the throttle. Don't know if the owners manual addresses this issue or not, may want to check.
7helpful
4answers
Ryobi stalls after starting.
Yep had same problem it would run for about 20-30 sec and then just stall.
solution is the diaphragm on the side of the carby I swapped mine for the same one in my blower and it fixed the stalling problem.
The diaphragm operates the fuel into the carb. loose fuel lines can cause similar problem.
10helpful
Ryobi straight gas trimmer, runs rough at idle and up to 1/2 speed, but great at full speed. Bought a reconditioned one.
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
* For this specific problem, i would say you should probably just adjust the "L" screw and hopefully that will help
146helpful
13answers
My Ryobi weedeater engine keeps stalling out.
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Good Luck!
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
