s
saiprasad Posted on May 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp desjet f380 not printing problem?? - HP Office Equipment & Supplies
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on May 01, 2015
HP Master
Level 3:
Answers
1124
Questions
Helped
451107
Points
2591
Step1: Check printer is powering on or not., if not check the adapter.
step2. Any error lights are blinking on panel?..check
step3: Cartridges are conditioned or not?.. if not,replace them..
step4: If every thing is fine, check for copying..if copying happens properly..go to next step.. or else go to step2 and check once again properly..
step5: check proper drivers in system., or else
step6: un install existing drivers.
step7: connect usb cable check for new hard ware found popup.. if not check usb cable..
step8:Install full feature drivers from below said link:
http://support.hp.com/us-en/drivers/selfservice/HP-Deskjet-F300-All-in-One-Printer-series/1129389/model/1129390#Z7_3054ICK0KGTE30AQO5O3KA30R1
I HAVE INSTALL THE HP DESJET F 380 BUT I DO NOT INSTALL THE I NOT GETTING SETTING ABOVE MAINTION PRINTER PLZ DESCRIBE THE SETTING
I think the printer is not installed properly into your system, i would suggest you that first uninstall the printer drivers and then try install the drivers, and about settings, after installation that would create the default printer icons on your system, use those icons to print or scan documents. please let me know that helps or not
2helpful
HP DESJET 694C - NO LONGER PRINTS IN COLOR - TRIED SEVERAL CARTRIDGES, CLEANED PINS, ALIGNED AND REALIGNED - NO CHANGE.
Did you checked Printer Settings? May be option is check Marked that "Always print in Gray Scale" if yes then remove check mark.
Disconnect printer from computer and Try to press resume copy or start print button for 5 seconds to start Test Print directly from printer. it prints in color then there definaly a setting problen in your computer printer settings.
Last Option is to check or replace print head.
F380 hp printer not printing from laptop
hello heilp me my printer is all light biping
F380 connected to airport express - usb /cannot print
Look for the drivers for F300 series - you may need to download them from HP's site. They're generic, but they work - unless you're trying to print through Airport!
Hp diskjet f380 not printing
Hi , prnter does not respond within a few seconds , the printing jobs are backlog , it must be delete all or cancelled it , so that the printer can move on.
HP 5150 will not print from programs MS Works and MS Word.
ayant egere le CD d'installation de mon imprimante hp desjet 5150, je ne parviens pas a installer mon imprimante. ou puis-je touve le driver, le lien sur le site hp.
merci par avance
5answers
HP Deskjet F380 Paper Problem
http://www.nodevice.com/driver/company/Hewlett-Packard/page3.html
k24674
Grand Canyon Tech
Grand Canyon Tech
