Microwave Ovens Logo
A
Anonymous Posted on Apr 30, 2015
Lg microwave mc-2681ds working very slow in convection mode . what yo do?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 20, 2008
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 23, 2008
SOURCE: instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Anonymous
  • 25 Answers
  • Posted on Jan 14, 2009
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
Anonymous
  • 8909 Answers
  • Posted on Dec 12, 2010
SOURCE: Sharp R-930 convection/microwave works fine in all
For that problem I would check the sensors. If the sensorblock is faulty, it will think it is hot when cold etc.
Hope this helps.
Anonymous
  • 8909 Answers
  • Posted on Jan 04, 2011
SOURCE: i have a Panasonic NN-C2003S
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional.
Hope that helps.
NOT AUDIO PLAYERS - ITS A MICROWAVE/CONVECTION OVEN
Hi Denise, I send you the link to download the user manual of the Microwave LG
Regards Franco Dosil
Hola Denise, te env?o el link para que descargues el manual de usuario del Microondas LG
Saludos Franco Dosil
https://www.lg.com/za/support/support-product/lg-MC-8083D
x
I have a lg microwave oven model mc-2681ds stopped working the service centre people say its circuit board needs to b replaced . coz of 6-7years old model the company doesnt have its spare circuiT.
Before you dump it, if it is totally dead with no lights or anything, I would check to make sure that the fuse inside is okay. Make sure that the unit is unplugged and turn it around and take the screws out that hold the cover in place and then remove the cover. Look for where the power cord goes into the back of the microwave and follow the black wire from the cord to wherever it ends. It should end at either an inline fuse folder or at a small circuit board. If it goes to a board, your fuse will be mounted on that board. Remove the fuse and have it checked with a multimeter set for continuity. If it is bad, replace it with the same size fuse, you will find the size stamped on one of the silver bands at each end of the fuse. It will be either a 15 amp or 20 amp fuse usually. If you put in a new fuse and it blows right away, that means you have a short somewhere and you would need to have a repair tech look at it. Hope this helps!
How to use mc what is the indication of mc , grill, and convection and which type of utensils can be used
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Microwave has stopped working and now I receive a flashing No10 in a square and a flashing No 1 in a square.The rest of the oven works, the convection side, What now....help!?
My wife cannot wait forever for me to solve the problem with our Microwave....so I nhad to bite the bullet and take it in to LG for repairs.
Thanks for the good site
Lost instruction manual
Hi - You can download the manual from the link below:
MC-924JLR
Please update the question & let us know if the information given was useful to you - Good Luck!
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
