Microsoft Windows XP Professional for PC Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install arabic language to my computer
I have almost all languages in my computer except arabic language so how to install it . thanks for the help
Anonymous
Level 2:
Sergeant:
  • Expert 154 Answers
  • Posted on Jul 11, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
154
Questions
0
Helped
64400
Points
506
1. Click on the start and go to Settings - Control Panel 2. Open the Regional and Language Options applet 3. On the Languages Tab check the "Install the file for complex script and right to left languages" checkbox to select it 4. Click OK 5. Insert the Microsoft Windows XP CD when prompted and allow installation to complete 6. Restart the computer when prompted to do so
1helpful
I want add arabic language to Samsung GTS5830
HEY HI
ITS A GODD IDEA TO USE THE COMPUTER IN A LANGUAGE WITH WHICH YOU ARE COMFORTABLE
Here are the steps you should follow to install additional language packs on your computer.
Open up Control Panel. Click on Change Display language under Clock, Language and Region section.
In the dialog that opens, see if the language you are looking for is installed on your computer. If it is you can choose it, or else click on Install and Uninstall languages.
In the resulting screen you can choose to install using Windows update, or if you have downloaded the files separately you can choose the second option to Browse computer or network.
Now simply point it to the folder containing the downloaded language pack. The wizard then lists the languages that are included in that language installer pack.
Choose the languages you want to install, click Next. You will be presented with the license agreement. Read through and choose to Accept or Decline the license. Naturally, you should choose to accept.
The installation will take some time. Once the it has finished, you can choose the newly-installed language.
AND TRY TO FOLLOW THIS LINK:-
http://cookieman56.tripod.com/arabic%20language.htm
YOU CAN TRY TO CONTACT MICROSOFT TO GET THE LANGUAGE PACKS AND UPDATES
HOPE THIS HELPS
HAVE A GREAT DAY
Arabic font nosupport
During a clean WinXP installation, the Arabic fonts are installed as part of what Microsoft calls
Complex Script fonts. (MS documentation.)
To add Arabic font support to WinXP follow these steps.
  1. Download fbarab.zip from this site.
  2. Extract the installation package from fbarab.zip with a decompression utility.
  3. Run fbarab.exe to install the Arabic keyboard layouts.
  4. Restart Windows.
  5. Load the keyboard layouts:
    1. Click on the Start button.
    2. Click on Control Panel.
      • The Control Panel is directly accessible in the standard Start menu but it is inside Settings in the classic Start menu.
    3. Click on "Date, Time, Language and Regional Options."
    4. Select the "Add other languages" task.
      • Or click on "Regional and Language Options" and select the Languages tab.
    5. Check the "Install files for complex script and right-to-left languages" option and click on the Apply button.
    6. Click Yes when you are asked to restart Windows.
    7. Go to "Add other languages" again and click on the Details button.
    8. Click on the Add button.
    9. Select Arabic in the drop-down list of input languages and select Arabic ASDF Eastern or Arabic ASDF Western in the drop-down list of keyboard layouts.
    10. Click OK as many times as you are prompted to and then close "Date, Time, Language and Regional Options."
For MS Office:
  2. Move the pointer over Microsoft Office Tools in Programs and click on Microsoft Office Language Settings.
  3. Select the Enabled Languages tab, check Arabic and click OK.
  4. Leave your preferred language as it is unless you really want to change it and click OK.
  5. Click OK.
I hope that helps.
I need to install or downloads Arabic language into my computer languages so I can type using Arabic keyboard thank you very much sam
Setting Up Arabic in Windows XP
Adding the Language to Windows
The following instructions will help you to set up your keyboard layout for Arabic that matches the DataCal Keyboard Labels.
Step 1. Install Supplemental Language Support
The Arabic language requires that you install Supplemental Language Support before you can set it up in Windows.
  1. Select the Start button in the lower left corner of the Desktop.
  2. Select the Control Panel (or, if you are using the Windows Classic Setting, select Settings > Control Panel).
  3. In the Control Panel, double-click the Regional and Language Options item.
  4. In the Regional and Languages dialog box, click on the Languages tab. In the Supplemental language support section, click on the Install files for complex script and right-to-left languages (including Thai) option (see Figure below).
  5. Click on the Apply button in the lower right corner of the dialog box and then click on the OK button. You may be prompted to insert your Windows install CD into the CD drive.
Step 2. Add Language to Windows
  1. In the Control Panel, double-click the Regional and Language Options item.
  2. In the Regional and Languages dialog box, click on the Languages tab.
1. Click on the Details button in the Text services and input languages section of the Language tab to open the Text Services and Input Languages dialog box.
2. To add a language, click the Add button in the Installed services section to open the Add Input Language dialog box.
3. Click on the arrow to the right of the selector in the Input language selector and scroll to Arabic.
4. The Keyboard Layout/IME should default to the Arabic keyboard layout. If it does not, click on the arrow to the right of the selector in the Keyboard layout/IME selector and scroll to the Arabic keyboard layout. Note that there often are different keyboard layouts for a language. You should select the language and keyboard layout that matches the DataCal Keytop Label.
5. After you select the language and keyboard layout, click on the OK button to close the Add input language dialog box.
6. When you return to the Text services and input languages dialog box, you will see the new input language and keyboard layout included in the Installed Services box.
7. Click on the Apply button to apply the changes to the new layout. Note that each language features a small blue box in the Installed services section with 2 letters that indicates the language. English is designated as EN.
  1. If you do not wish to add any additional languages or layouts, you can click on OK to close the Text services and input languages dialog box. When you return to the Windows Desktop, you can see the language bar in the lower right corner of the Desktop.
  2. To change the language and keyboard layout, click on the two-letter language selector box with the left mouse button to open the language selector menu.
  3. Click on the language that you wish to use in the language selector pop up menu.
The language you select will remain in effect in active Windows application until you select a different language. For example, if you select the Arabic language and keyboard layout in Microsoft Excel and English in Microsoft Word, each application will use that keyboard layout until you exit the application or you select a different language.
Default Keyboard Layout
If you wish to make a particular keyboard layout the default Windows layout (i.e., to be used in all Windows applications), open the Text services and input languages dialog box.
Select the desired keyboard layout to be the default in the Default input language section of the dialog box.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
4helpful
Help me change language of samsung SHG i300 Widows mobile
i have your solution but i need your help: i need ur arabic software cuz my i300 doesn't read arabic sms
if u can send it i'll be greatfull
your solutionis is to format your mobile (dont worry your files will be saved): tunr off your mobile, hold on ( 0 ) and press the start bouton(red bouton) it will takes 3 to 5 min . now ur mobile is like new with english language!!!!!!! enjoy
my mail is [email protected] if u can help me!! thx
46helpful
4answers
Change windows xp from arabic to english
reinstall service pack 3 with language pack from microsoft.Make sure you back up your registry first.
For xample
If you have XP SP2 in ENG and want to have it iArabic, you will have toDownload SP3 in Arabic (http://www.Microsoft.Com/downloads/details.Aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en change language to desired one then download), change some registry Keys (go to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language Registry Key, and then change the value date for “Default” and“InstallLanguage” Registry value from 0001to 4001) reboot and you'll be able toInstall SP3 in Italian.
  • 0001 = "ar;Arabic"
  • 0401 = "ar-sa;Arabic (Saudi Arabia)"
  • 0801 = "ar-iq;Arabic (Iraq)"
  • 0C01 = "ar-eg;Arabic (Egypt)"
  • 1001 = "ar-ly;Arabic (Libya)"
  • 1401 = "ar-dz;Arabic (Algeria)"
  • 1801 = "ar-ma;Arabic (Morocco)"
  • 1C01 = "ar-tn;Arabic (Tunisia)"
  • 2001 = "ar-om;Arabic (Oman)"
  • 2401 = "ar-ye;Arabic (Yemen)"
  • 2801 = "ar-sy;Arabic (Syria)"
  • 2C01 = "ar-jo;Arabic (Jordan)"
  • 3001 = "ar-lb;Arabic (Lebanon)"
  • 3401 = "ar-kw;Arabic (Kuwait)"
  • 3801 = "ar-ae;Arabic (you.A.E.)"
  • 3C01 = "ar-bh;Arabic (Bahrain)"
  • 4001 = "ar-qa;Arabic (Qatar)"
If noProblems occur, you will have the whole system language changed.
4helpful
2answers
I want to support arabic language to my phone
Hi, For arabic language support you will need to flash your phone to one that includes Arabic language. This involves 3 software instalations to your computer. Plus you need to be somewhat savvy with following software instructions. If you decide to do this please dial *#0000# on your phone and write me the RM-XXX number on the screen and then I will write you the instructions. Thank you
3helpful
2answers
I dont have arabic language in my computer list so i cant choose this language
hello u can download from here and here and u can download from google also but u should have internet or u should download from other computer and copy in to one pen drive or CD and install in ur pc ok bie and PLEASE RATE ME OK WITH 100% OK BYE
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
