Error code F7 or F4 with beeping, how do I stop it? Oven hasn't been used in a long time.
SOURCE: Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
SOURCE: f7 error in Kenmore double oven
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. I hope that it works for you too. Please let me know by sending an email to:
[email protected]
Regards,
Powerman
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
SOURCE: error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
SOURCE: kenmore oven
Hi
F1 Error indicates a bad control board and the control board
(electronic control) should be replaced to solve this issue. Hope this
helps...please post back for further assistance.
Daniel
