2. When yourToshiba Fax Machine detects a busy signal, Error 0050 suddenly appears on the display screen. This possible error may appear when on the other end a voice or recording picked up instead of the fax machine. ...Jun. 20, 2019
Mar. 22, 2018 - When your Toshiba Fax Machine detects a busy signal, Error 0050 suddenly appears on the display screen. You can always Resolve Toshiba Fax Error 0050 simply retrying the communication. This possible error may appear when on the other end a voice or recording picked up instead of the fax machine.
Toshiba E-STUDIO 555 Manual Online: Error Codes On Transmission And Reception. ... 0030 Polling Error 0033 0042 Memory full 0050 Line busy Security Mismatch ... the Internet Fax setting, or reduce the number of pages and perform the.
Not nearly enough info. Does this error code appear on your printer? What kind of printer? Does this error appear on your computer screen? Can't help without details
GE dryers use three-character codes that display on LCD
screens. Every code starts with "E" and is followed by a two-digit
number.
Power Failure
When your home loses power, the "E01" error flashes on the
screen. Reset the dryer memory by unplugging the device, waiting 30
seconds and plugging it back in. The error code will disappear.
Thermistor Errors
Errors "E02," "E03," "E04" and "E05" are thermistor errors.
The thermistor, when operating properly, reads the temperature of the
dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
When there is an error with the door switch and sensor, the
"E60" error code will appear. An unbalanced door will produce the E60
code. Try to close the door gently and listen for the click. If the
error remains, the door switch may need to be replaced.
Control Board Errors
The control board sends signals from the controls to the
dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE
service or install a new control board for the dryer
