Directed Electronics Dei Directed 450t 7 Channel Expander Module For Alarms Logo
A
Anonymous Posted on Apr 25, 2015
I have a viper 690xv,I want to install the dei 450t.what channel do I hook the blue/white lead to.
D. E. Hev
Level 3:
Genius:
  • Master 1,187 Answers
  • Posted on Apr 25, 2015
D.  E.  Hev
Master
Level 3:
Genius:
Answers
1187
Questions
Helped
424814
Points
5819
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 • Car Audio & Video
I have what i believe is a viper system in my truck i just bought it has a valet remote i CANNOT GET UNLOCK FEATURE TO WORK BUT IT WILL UNLOCK WHAT CAN I DO TO MAKE IT UNLOCK ALSO
There is a green and blue wire on a white colored harness. You will need to verify that these wires are connected to the lock and unlock wires in the vehicle. This green and blue wires are on a 3 pin harness plugged into the alarm.
How to install viper smart start modual
only a authorized dealer can program your unit and if you manage to install it only a dealer is able to activate it so i suggest to have an authorize dei dealer install it
2helpful
Viper 690XV Installing with INT-SL Data interface module
The number 2 pin on my cars OBD II is the data carrier which is then connected to the purple wire of the INT-SL Data Interface Module.
Data Interface Modules are becoming the standard for alarms and remote starter installations. These modules will make installations 75% faster and more accurate. I also recommend using Posi Taps to tap into your OBD II.
This a safe and 100% effective reversible method of connecting wires without crimping, cutting, or soldering. If you have any questions feel free to drop me a line or simply Google: "Posi Taps" by posi products. For Interface modules Google: "INT-SL". Good luck with your next installation. And remember the has endless resources providing you take time out to research them.
By the way my Viper install was a sucess.
Best regards,
Rico
1helpful
Need instalation manual VIPER DEI 300 CAR ALARM
http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
3helpful
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Top Directed Electronics Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Directed Electronics Home Security Expert? Answer questions, earn points and help others
