Question about Android LG Optimus Dynamic II LG39C Smartphone fo
Can't move sceen - Android LG Optimus Dynamic II LG39C Smartphone fo
Horizontal line moving from top to bottom
please replace the vga cable then check
Apr 16, 2014 | GVision P15BX Monitor
Lens will not move and is stuck also gives me a code on the screen of lens error1110033 and also need to find out if its under warrenty.
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 21, 2010 | Kodak Easyshare C813 Digital Camera
I get red dots in the black areas during dark sceens
http://www.retrevo.com/support/Maxent-MX-42HPM20-TVs-manual/id/278ag118/t/2/
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
www.scribd.com/.../SONY-KDL42XBR950-TV-Plasma-Training-Manual
Use these links, user manual and two training manuals, these should help you isolate your problem
May 21, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Convergence problem Mitsubishi 6043
DOES IT AUTOMATIC CONVERGENCE,,TRY THAT,,IN THE MENU,,TRY NEW JACKS
Mar 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
Jan 14, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Can you please tell me how to move the sceen up down on the elo touichsceen
Are you talking about realigning the screen?
http://www.elotouch.com/Support/TechnicalSupport/qsalign.asp
Dec 05, 2008 | Computers & Internet
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Android LG Optimus Dynamic II LG39C Smartphone fo Logo
Top Android Cell Phones Experts
john smith
Steve Sweetleaf
Steve Sweetleaf
Dakshinamurthy...
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
