Computers & Internet Logo
s
stellahayes Posted on Apr 23, 2015
Question about the compatibility of GLC-SX-MM with GLC-SX-MMD.
Hi ALL, My query to all of you is that if I connect a GLC-SX-MM at one end and GLC-SX-MMD at the other end, will the link come up. The difference between the modules is that one supports Digital Optical Monitoring and other does not.
Mark Twain
Level 1:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Contributor 12 Answers
  • Posted on Jun 20, 2016
Mark Twain
Contributor
Level 1:
Passionate:
Habit-Forming:
Answers
12
Questions
Helped
1559
Points
43
According to Cisco Compatibility Matrix, GLC-SX-MM and GLC-SX-MMD transceivers are the 1000BASE-SX SFP transceiver modules for MMF with dual LC/PC connector. The only difference is that GLC-SX-MMD has additional function of DOM support, which may not affect the compatibility.
candytang
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Apr 24, 2015
candytang
Contributor
Level 1:
New Friend:
Answers
21
Questions
21
Helped
3833
Points
55
As long as you are using the correct patch cable (MM) and your backbone is also MM, then yes. The GLC-SX-MMD and GLC-SX-MM are compatible.
GLC-SX-MMD and GLC-SX-MM, are they compatible with each other?
Yes, the GLC-SX-MMD and GLC-SX-MM are compatible with each other, and the difference between the two is that the GLC-SX-MMD transceiver has additional support for Digital Optical Monitoring (DOM) capability. For more tech support, you can consult with our CCIE expert - Bill, and his e-mail address is as below:
[email protected] GLC SX MMD Price Cisco SFP Modules GLC SX MMD 3Anetwork com
2answers
I got my piston in my ktm sx 125 blown up im wondering must i open the entire engine to fish out the bits i don't fink dat are there?? my crankshaft spins freely in the crankcase not rubbin on any bits of...
Thanks for contacting FixYa. I was reviewing some of the older un-answered questions trying to ensure your issue has been resolved.
You should be able to resolve this issure by just removing the top end. You will have to remove the tank, the pipe, disconnect the carb, any water hoses, and possibly the radiator. If there is no damage to the connecting rod you be able to thoroughly clean the crankcase withough removing the engine. If you have damage to the top rod end you will have to pull the engine and split the case to replace the connecting rod.
TF
We are terminating a 24 OFC in a Cisco 2950 g switch using GLC-LH-SM transceiver,Physical connectivity everything correct for both end.Same We checked & Confirmed with Media Converter, Link cames Up,...
Dear,I work for Ingellen Communication Equipment and we are a large fiber optic products manufacturer in Shenzhen.Kindly let me know your specific requirements so that i can help.
More details
2answers
GLC-LH-SM with a Catalyst 2960 switch
Cisco disables the trans port as default, have you enabled it in the system?
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
