I have a Jen-air dishwasher model JDB1100AWS. It will fill but once full the motor will only spin for a few seconds then stop, then pause for about 5-10 sec and spin for another 2 sec. It does this for a cycle of 4 spins and then the control panel lights go out as if it were done. When done, it has not drained the water. I can start and then immediately cancel a cycle and it will drain the pan. I replaced the control panel less than a year ago. so... the control panel is new-ish the motor does spin. the machine fills and empties. it has all the same symptoms when I start a normal or a heavy cycle what are your thoughts?
SOURCE: Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
SOURCE: jenn_air model #JD8910AWS won't drain
I was having the following symptoms: If I hit the drain button, it would stay at 2 minutes and just click on and off. If I hit the rinse button, it would rinse all 9 minutes OK. It would always stick in the middle of a full cycle and just start clicking.
I just fixed it. I shut off the circuit breaker, opened the door up (all torx screws from inside of door) to get the the upper controls. One lead (of two) of a capacitor (square blue component) had actually worked itself out of the control board. I cleaned it up and resoldered it in. All better now - for now.
SOURCE: Jenn-Air dishwasher jdb1100aws problem
I had the same problem , needed a seal kit w/ alignment tool.
repair part # 99003341.
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
SOURCE: Jenn Air DW961UQW Partially Fills, Drains and Done
is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
UPDATE: After posting this question, I continued to troubleshoot the issue. I discovered that, while these symptoms were very reproducible in the normal and heavy cycle settings, I tried the other three settings (china, rinse only and quick wash) and they worked fine. After that ... the normal an heavy worked fine too! SO the solution to this problem was to simply start the machine in a different cycle. It is unsatisfying to not have an explination or a part to replace, but the solution, though mysterious, is free!
