if you have not changed the camshaft position sensor you need to do that sounds exactly like my problem got the new fuel pump and filter in there and it was fine for a month then same thing started happening again, been fine for 7 months since I changed my camshaft position sensor
i no what you mean if you grease the slot you gonna have more maintenance to more often coffee dust goes in that grease have to clean with hot water more often but its what you have to 95% of time when those machine break down its bad maintenance had mine for over 14000 shot the only thing i had to do beside maintenance is completly dismantle the brew group for a good clean up that it clean or machine once a mounth descaling it every 3 mounth you gonna have it for a long long time p.s the grease make it easyer for the gear inside thanks
I have that MB myself, and i have non problems what so ever.
To pass that F1 problems u can sett in bios "Stop at no error",
To get the sound try to reinstal the drivers, not from the folowing CD, download them from ASUS site http://support.asus.com/download/download.aspx?SLanguage=en-us
lift our car remove the motor mounth and the braket to its easyer most of the time that mounth is broken lots of oil on it remove starter disconnect battery under the trasmission on the housing not the pan put a leg or a jack lift it up as high as possible remove oil pan bolt remove and repeat step dont forget to remove that braket and mounth thanks pierre
