Enter the number just as you would to make a call. (but do not make the call) Then click the button down on the lower left. Then click "add to contacts" from the list.
Add a New Contact
Step 1
Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2
Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3
Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1
Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2
Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3
Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Hi, if you go into your contacts/phonebook there should be a "+" sign, press this and you should be able to manually add a contact and click save when your done, repeat for further contacts.
Click Gmail at the top-left corner of your Gmail page, then choose Contacts.
Select contacts that you want to add to a group, click the Groups button. , then Create new.
Enter the name of the group.
Click OK.
To add contacts to a contact group:
Select the contacts in the Contacts list.
Click the Groups button.
Select the group you'd like to add the contact to, or select Create new to create a new group.
If you have multiple addresses saved for a contact, you can choose which address should belong to the contact group by opening the contact and clicking the small arrow next to the group you'd like to modify.
Follow these instructions to add new contacts on your Nokia Lumia
On Start, swipe across and tap People.
Tap the New icon (+) at the bottom.
Tap Name to add First name, Surname, Title, Company name etc then tapSave.
Tap Phone to add a contact number and tap Phone number type to choose the type of number then tap Save.
If you wish to add further information such as an additional phone number or an email address, tap to add more details or press Save to store the contact to the People Hub.
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
• First name/Last name: assign a name.
• Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type or Mark as default number.
• Email: assign an e-mail address.
• Graphic ID: assign a caller ID image to alert you to a call from the person.
• Ringtone: assign a ringtone to alert you to a
• Group: assign the number to a caller group.
• Birthday: enter the person’s birthday.
• Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
• Name: assign a name.
• Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
