Every time I turn on the tablet by holding the power button it brings the "swipe to shutdown" option then simply goes black (ie doesn't go through the actual shutdown phase). If I don't swipe the screen also goes black. Is there some other way to reboot the tablet?
SOURCE: rebooting when try shutdown
It seems that some minor windows files are corrupted, you needed to insert the Windows XP CD and try to fix the files by re-installing the system... this will restore the corrupted files.
Good luck.
SOURCE: My windows xp keep rebooting after shutdown
It might be the problem in your smps also or just clear your CMOS or enter f8 button while booting and stop restarting in the option"stop restarting windows "
SOURCE: My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
SOURCE: windows xp startup and shutdown has changed!
To configure Windows XP to use the default logon and shutdown screens for every logon session, follow these steps:
Thanks
proton
SOURCE: PCCharge worked fine yesterday. I
I have a diferent problem. I connect ok with satellite connection but not with terrestrial connection with the same PC, and same software. Can be a problem with MTU???? What other problem can be?
NM found the reset button in the back.
