If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
SOURCE: vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
SOURCE: green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
SOURCE: Vertical line on LCD TV Panel
No solution here.
I have the same issue... A vertical magenta line, about 2 pixels wide, appeared about 1" from the left side of my 52" LNT5265FX/XXA. Of course, this appeared after the 1 year warranty... For me it started showing up about 22 months from purchase date. It goes away when the TV warms up after about 30 minutes or so. Sucks that such an expensive product has developed this issue w/in 2 years.
