SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at
fault and without some technical background and a couple of test instruments,
you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it
stand overnight or at least several hours, remove the back panel and look for a
separate board with mostly larger components on it; it will have a ferrite core
transformer on it and several larger capacitors which are cylindrical and
mounted vertically to the board.
Before touching anything inside,
especially on that board, allow several hours to be safe since the larger
capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating
such as discoloration of the board material, it may not be repairable but if
you can find a part number on the board, you might be able to buy the power
supply and install it yourself.
If there are no signs of heat
damage to the board, there may be companies offering to repair it as a
subassembly instead of repairing the whole set which could be much more
expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most
are capable of switching on and off if a downstream problem is causing an
overload.
SOURCE: 42 inch Vizio will not stay on
There are 4 scenarios.The most afford part out of these scenarios starting at $215 to $850.
My recommendation:
A. use a repair tech.
B. Buy a new TV cause there are knock out deal right now at circuit city(chapter 11)!
solutiondoct
SOURCE: Plasma TV
Hi and welcome to FixYa,
To get a good signal on all TV units, the source must be good and strong. The source could be an aerial antenna or connection to your local cable provider. The message "No Signal" indicates that the TV cold not receive a decent TV signal. With this in mind, possible solution wouold then be to increase/improve the incoming TV signal:
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
SOURCE: TV only works for 5
Nothing you're gonna be able to fix yourself... Sorry but you're gonna have to take it somewhere to fix that particular problem
