When I try to print 1 label, it will skip 5 print 1 then skip 1, it was working great I don't know what we did? Help
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Also open your printer driver preferences and make sure the label length is set to MORE THAN the length of your label. If your labels are 2 inches high and the preferences are set to a 1 inch label, the printer's sensor will stop looking for a gap after 1 inch of feeding. When this happens it will eventually find a gap and print, but you will waste a lot of material.
