Question about LG Goldstar LD65EL Dehumidifier
LG Dehumidifier Fan
Should the fan be snug on it's axle? Mine spins freely. If it should be tight on it, is there anything I can try, short of replacing the fan/motor units? I have the 65 pint unit.
  • LG Master
  • 43,501 Answers
There are many reasons for a dehumidifierLG Dehumidifier Fan - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
6ya staff
SOURCE:
MY DEHUMIDIFIER COMPRESSOR SOUNDS LIKE IT IS RUNNIN BUT, THE FAN WHEN ENERGISED IS TIGHT & WILL NOT RUN. WHEN NOT ENERGISED THE FAN SPINS FREELY. SHOULD i REPLACE THE FAN MOTOR???
Definitely sounds like the thing to do. However, before you do that, try lubricating the fan motor shaft with some light oil (like sewing machine oil). That may free it up.
Jun 28, 2011 | LG LHD65EBL Dehumidifier
Fan not working, outlet is live, product is 6 mos old, located in an indoor swimming pool (endless swim machine) Hi E Dry 100,
If the fan does not operate with the fan switch set "on", there is a problem with the power supply, internal wiring, or the fan itself.
First make sure the dehumidifier is plugged in to a working outlet.
Next unplug the dehumidifier and remove the cabinet cover. Check the internal wiring for loose connections.
Next remove the fan and check that it is able to spin freely (by hand). If it spins freely, it should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
Feb 22, 2011 | Therma-Stor Hi-E Dry 100 Dehumidifier
It is heating up the place and its very loud.
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Good luck.
Aug 14, 2010 | LG LHD65EBL Dehumidifier
Fan does not work
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 16, 2009 | LG Goldstar LD65EL Dehumidifier
Will not run - compressor runs
Aug 14, 2009 | LG DH30 GoldStar Dehumidifier
Fan does not operate in my 54501 Kenmore dehumidifier; therefore, unit gets very hot.
Aug 11, 2009 | Kenmore 54501 Dehumidifier
Fan not working
Jul 31, 2009 | Fedders A7DH65B2A Dehumidifier
I have a LG LHD45EL and the compressor works, fins chill but fan won't turn at all. I took it apart and cleaned the armature of the fan, Used a non-contact device to ensure electric is present in the...
let the unit cool down
with power on try sticking something in there to spin the fan blade
if it spins and continues to work it is a bad capacitor (little shiny metal can sometimes oval or round)
if it doesnt spin i would have to guess the motor is bad
hope this helps
Jul 29, 2009 | LG LHD45EL Dehumidifier
LG LHD65EL Dehumdifier Fan Noise
It sounds like the fan has etached from its hub. This usually is not repairable if that's the case. Replace the fan.
Jul 03, 2009 | LG Goldstar LD65EL Dehumidifier
LD65EL Dehumidifier rumbles and has poor air flow
Sounds like the bearings have failed in the fan motor, & the rotor is rubbing on the stator. You mentioned end play in the shaft, check for cross play. There should be no perceptable cross play, any found indicates a need for a new motor.
Jun 20, 2007 | LG LD65EL Dehumidifier
Dehumidifiers Logo
207 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
