Try to connect via lan cable.if u get online then look for wifi switch !
Try removing battery, and holding power button for 30 seconds and then replace battery and power on and test.
***the Ethernet cable plugged into ur Netbook will negate the Wi-Fi*** But, Yes, I agree, if u can't find internet options and Wi-Fi switch (Wi-Fi is in internet settings), u should connect via an Ethernet cable...if u can connect to the internet with a cable this means that the Wi-Fi is turned off. U see, the Ethernet cable plugged into ur Netbook will negate or disable the Wi-Fi. Also, try unplugging Ethernet cable & finding Wi-Fi switch inside internet options. Since the Ethernet cable negates the Wi-Fi, maybe unplugging the Ethernet cable will solve ur problem.
