Sewing Machines Logo
Sue Roe Posted on Apr 08, 2015
My Husqvarna Viking diamond series embroidery machine does not recognize a formatted disc
Embroidery machine trying to format a disc it would read I did have some work done to my computer but I don't think it would hurt that
Husqvarna Viking Designer Diamond Deluxe sewing and embroidery machine. Code for service mode on Designer Diamond Deluxe?
Question edited for a lot more clarity.
Question moved from Watches to Husqvarna Viking.
https://www.manualslib.com/manual/1054795/Husqvarna-Viking-Designer-I.html?page=6
Also found this
Follow the instructions in the Installation Wizard. When asked to enter your Installation Code, enter the following number: 9200.
and all this
I am needing a service code password for my Husqvarna
JustAnswer https://www.justanswer.com > small-appliance > ciwzd...
Jun 18, 2019 - I am needing a service code password for my Husqvarna. I am needing a service code password ***** my Husqvarna Designer Diamond sewing machine.
1 answer · Top answer: Just go to the tools screen and look at the timer which will give you the hours and minutes ...
SOLVED: Service Menu For Husqvarna Designer SE
Fixya https://www.fixya.com > ... > Husqvarna > Designer I
Hi SewTechWayne, do you happen to have the latest pass code? 5031 is no longer working on my machine. Thanks!
User's Guide
Husqvarna VIKING https://www.husqvarnaviking.com > ClientSite
When asked to enter your Installation Code, enter the following number: 9200. 5. In the 5Dâ„¢ Configure Wizard under MyMachines select your machine type: ...
140 pages
Husqvarna Viking Designer I Service Manual [Page 6]
ManualsLib https://www.manualslib.com > ... > Service manual
Husqvarna Viking Designer I Manual Online: Service Program. ... Press Handling Get into the service program of the machine by pressing the reverse feed...
1helpful
Which software extensions can be used with a Husqvarna Ruby embroidery sewing machine?
The Husqvarna Designer Ruby can read a number of embroidery file formats: .SHV, .DHV, .HUS, .VIP, .VP3, .PEC, .PCS, .SEW, .JEF, .EXP, .10*, and .DST. One other embroidery file format is accepted. See the manual. It can read the .SH7 stitch format files and .VF3 embroidery font files. It can also read .HTM/ .HTML and .TXT files. With the complimentary 5D software (or a similar package), you can convert most other embroidery files to one that is compatible with the Designer Ruby.
The documentation for many Husqvarna Viking sewing machines is available here: http://www.husqvarnaviking.com/Support . The manual and other useful information for the Designer Ruby is here: http://www.husqvarnaviking.com/support/DESIGNER-RUBY . The current link to the manual is http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_Ruby_manual_ENG_A.pdf?ext=.pdf . The file extensions are listed on page 9:2 (page 100 of the PDF).
I hope this helps.
(I will admit to mostly using the .HUS files with the Designer Ruby.)
Will bernina art-link software work on my brother se 400 machine?
.pes - A stitch-based file format used by Brother and Babylock embroidery home sewing machines. .pec - A stitch-based file format used by Brother and Babylock embroidery home sewing machines. .hus - The stitch-based file format used by Husqvarna/Viking embroidery home sewing machines.
The .exp format is a commercial format while .art is a BERNINA-specific embroidery format. Embroidery designs in .art format keep their fancy fill effects even after rescaling the designs whereas the effects may be lost when editing .exp format files on the machine.
no not think so
2answers
On my Husqvarna Viking sewing & embroidery machine...when I put in a floppy disc I get the error message: General disc error. What is wrong?
It can't read your disc, it may be damaged or needs to be cleaned. It could also be the wrong disc for the machine. The machine can't recognize it.
I the floppy discs that control my Designer 1 embroidery machine
You can have replacement discs ordered from Husqvarna Viking. Visit an authorized Husqvarna Viking dealer for them to order the replacement discs. However, you might luck out and they have some already on hand from a scrapped machine or a trade-in. You can find your nearest dealer by visiting the Husqvarna Viking website - http://www.husqvarnaviking.com and clicking on dealer link down the left side of the page.
Good luck.
1helpful
My mom purchased a USB stick @ a computer store to load her software on to her embroidery machine. However when she puts the stick into her embroidery machine it tells her it is empty. What could be the...
You can't just copy the files to the stick, you need to do it through the Husqvarna software, which then writes the files in a format that the sewing machine can read
Internal timer on Husqvarna Diamond
Sorry, this is information only provided to certified husqvarna viking service technicians. You can see the sewing hours in the user interface by going to the 'tools/set" menu.
Probel with Embroidery disc
I am pretty sure you can download Disk 100 free from the Husqvarna Viking website. This has all the embroideries that came free with the machine, plus the alphabets (I think!). You can download this direct to your PC or to a set of floppies, depending on what your Designer needs and what support software you have (or have not) got. If you have no Husqvarna software at all, your PC will not be able to read the floppy. It is in .shv format which PCs are unable to read, being an embroidery machine language only.
If you are trying to open the faulty disk in your Disk Manager software, I always found it worked better if I didn't put the disk in the floppy drive of the computer until after I had already opened Disk Manager.
Hope some of the above is useful to you.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
