My DVD player JVC TH-A35 is hooked up to my TV via a scart adaptor supplied to a dedicated AV1 input. I get backgound sound but no speech or dialogue. Help!
SOURCE: TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
SOURCE: I want to connect a Virgin HD box to my Panasonic
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
SOURCE: I cannot record from a Daewoo DVD recorder (
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
